When I use USB-IN from my PC, I can’t choose USB-OUT as an option, I get a message to change from USB In mode. Why USB-Out only works with other input modes?
This behavior is normal. USB-IN mode is designed for using the ROSE device as a DAC with an external source such as a PC. When USB-IN mode is active, the audio signal path is fixed to the USB-IN input.
USB-OUT is intended to output audio from the ROSE device’s internal sources (streaming, local files, network playback, etc.) to an external DAC. For this reason, USB-IN and USB-OUT cannot be used at the same time.
To use USB-OUT, please switch from USB-IN mode to another input mode before selecting USB-OUT.
