USB Output Issue
Hi there,
I have just bought an external DAC, an audio gd r7he and in trying to use the USB digital out I’m having issues. It will play a couple of minutes of a song, or film from TV (via optical into the Rose, then USB out of the Rose into the DAC) then just stop.
I’ve used the coaxial out and that seems to work fine, but doesn’t sound as good.
Am I doing something wrong, or is there an issue with the USB out?
Thanks,
Paul
Hi Paul,
I have the same issue with USB and posted on here a few months ago hoping to get a resolution but no joy and gave up in the end
Bumping this for comment from the team.
You all haven’t told what model you are referring to?
I have my 130 connected with both USB & Coaxial to my 2 DACs and switching them in between and working flawlessly. Both connections sounds as good and it is convenient by using the app to switch them.
But if I serve two DACs both connected in USB. It will come with problem (USB-dac & one other USB port used). It sometimes cannot recognized with one another. They would be in mess and can’t switching them easily… I need to try by luck in this regard. I supposed not much ppl would prefer connecting 2 DACs in USB. Hope the coming Fibre hub will solve the problem connecting both DACs in the same hub.
