USB power settings behavior in stand-by
I am using an HiFi Rose RS130 and I am trying to set:
System Settings → USB/SSD power activation in standby mode → OFF
The problem is that the setting is not saved.
My setup:
  • RS130 connected via Ethernet/Optical
  • Wi-Fi is disabled
  • I select OFF
  • confirm the setting
  • afterwards the setting has switched back to ON
The RS130 also shows the message that when Wi-Fi is enabled, USB/SSD power in standby must remain ON. However, in my case Wi-Fi is definitely OFF.
I would like to use the USB power state as a trigger for another device, so I specifically need the USB ports to switch off when the RS130 enters standby.
Has anyone else seen this behavior?
Is this:
  • a known firmware bug,
  • expected behavior in the current Rose OS version,
  • or is there another setting that has to be changed first?
I can also provide screenshots showing that OFF can be selected, but the setting returns to ON afterwards.
Thanks!
@Heiko
An issue has been identified in your specific environment (when the Wi-Fi USB dongle was unplugged while Wi-Fi was ON), and it will be fixed in the next release.
To use it normally in the current state, please follow the steps below:
1.Reconnect the Wi-Fi Dongle:
Plug the previously used Wi-Fi USB dongle back in.
2.Verify Wi-Fi Status:
Ensure that Wi-Fi is turned ON.
3.Turn Off Wi-Fi:
Switch Wi-Fi to OFF in the settings.
4.Remove the Dongle:
Unplug the Wi-Fi USB dongle.
Thank you. I have not tried it yet but I never had a WiFi usb dongle plugged in?!
I had an external usb CD drive but I already removed it without success. WLAN has never been configured in my system.
Any other idea? When will the fix be provided and rolled out?
Thank you for your response
BR
Heiko
The latest release fixed this issue. Thank you :pray:
@Heiko
Thank you for sharing the results after the update.
