I bought a RS150-B from a friend that had it registered in his name. What is the best way to take out all of its information from the machine? Can it be done by performing a factory reset? Can I do it without affecting the machine?
You can do a factory reset. Follow the link to the PDF of the 150b manual and there are steps to follow for factory reset.
