After updating to the latest version of software on my 150B I have noticed disruptions while playing from my Apple Music on iPhone. Can you advise? I am really disappointed with such a ”premium” product….
Please check a few things.
Are you experiencing the phenomenon of the audio being cut off in the middle when you update your RS150b to the latest version, connect it to your iPhone via AirPlay, and play Apple Music music on your phone?
Are your RS150b and iPhone both connected to the same network?
Does the connection get cut off even after you factory reset your RS150b and reconnect it to your iPhone via AirPlay?
