Using Ethernet or Wi-Fi
If you have a RS 150B, are you using a Ethernet cable or Wi-Fi to connect the unit?
Do you find any difference in sound quality between the two?
There are various opinions about sound quality, so I will not comment on it.
However, Ethernet is recommended for stable music and video playback.
Thank you,
Helle there,
What if ethernet is slower then wifi?
With wifi i can play with no problems and with ethernet it often crashes…
If WiFi works it’s fine, you can use it that way, but there is definitely something wrong with your network…
