Hi, i have a RS150B and love it!
I want to use HQ-player with Roon to upsample music files. I heard some very good results with this.
I believe that the RS150 lacks the necessary NAA ( Network Audio Adapter that HQ-player uses to send a music stream to the endpoint).
do you have plans to add the NAA-support? I think it would be a great addition to a super -streamer.
If not, can you recommend a solution that works as a NAA endpoint with USB output to send music into the RS150 from HQ-player?
thank you kindly.
