Can anyone help me what setting should i need to change if i want to bypass the pre amp functionality of the RS250.
Appreciate your help in advance.
Thanks!
Gilbert
Thanks!
Gilbert
Set output to usb, coax or toslink and add the external DAC.
That’s all you’ve to do.
I don’t think, that you can completely bypass the preamp in using the analogue output from the RS250 (only setting the output level to fixed and set the gain).
By the way: The RS250 seems to be a mimosa in using USB cables connected with the USB DAC.
Thanks, Burki. Appreciate tje info.
could you please clarify “mimosa” in your post? Thank you. Sorry, I don’t get it.
