Anyone else find VU meters don’t move much .
Yes, I found the same. They used to move quite fast and much more sensitive. Now they don’t move much since few days ago.
If you press the gear icon in the output settings of In/out setting, the Software Volume Control item appears.
Is this set to On? When it is off, the Vu meter works normally, but when it is on, the movement of the VU meter is slow, so our SW development team is reviewing it.
