Hi there,
I have various problems with my RS250 device.
No tag information when streaming.
I stream the music from my Synology Nas with my Surface-Pro to the RS250 via the MediaMonkey 5 client. Often no tags and covers are displayed on the RS250. The first song is displayed normally, then when the next song started, the information is missing, the progress bar works and shows the correct time. If I stop the playback and start it again, the information is displayed. In between, information is also displayed from time to time.
Sometimes playback from a playlist in the MediaMonkey application skips a song. The first second is played and then the next song is started immediately.
I previously had a Marantz NA6005 as a streamer, the behavior did not appear there.
3. My database cannot be built.
The data from my NAS is integrated as a drive on my Surface Pro via Windows sharing. The NAS folder is also integrated in the Rose Connect software (latest version).
I can also browse through the data here.
However, nothing is displayed in the settings
I’ve already tried a DB reset and a delete and to no avail. I have already reset the device.
What can I do to fix the problems?
I thank you for the support.
