Hello @ROSEHAN,
I’m experiencing an issue with my RD160 that only appears after extended use. After several hours of operation, a vertical line appears in the middle of the display, as shown in the attached photo. The line is not present at startup but gradually appears over time. Restarting the device temporarily resolves the issue, but after a while, it comes back. Other than that, the RD160 functions perfectly. Do you have any idea what might be causing this? Could it be a software or hardware issue? Is there a known fix for it? I’d really appreciate any insights or advice you can share. Thanks in advance for your help!
Best regards,
Philipp
