Hello to the Hifi Rose team.
Would it be possible to add the possibility of choosing 24P video output? What would be even better would be automatic switching of the video format depending on the file being played. This function has existed on all video players for almost 20 years, it shouldn’t be that complicated…
Thanks in advance.
To achieve high-quality sound, we use AV Sync and Audio Clock as the master when playing video.
In the case of video during clock synchronization, you may feel awkward if only one or two frames are missed or delayed out of 60 frames.
Also, in the case of 30 or 24 frames, the frames must be exposed evenly for 1 second, but if there is a slight delay or delay in the interval between each frame, it may play awkwardly.
Regarding this issue, we are trying to play both video and audio as smoothly as possible, but there are limitations due to the nature of the current system. However, we are continuously tuning it. We are making improvements to ensure smoother playback.
If you compare it visually with the past, there may not be much change in the awkward playback, but if you compare it numerically, a year ago, 4K 60 frame Rose Tube video was played back and forth between 45 and 65 frames per second, but now it is 55 frames per second. Playback occurs by switching between 65 frames.
And recently, in the case of 24-frame Rose Tube, we are trying to improve it so that it can be played more naturally.
