How do I keep VLC from resampling audio? It doesn’t play in the original playback bit rate via USB output. It plays a different rate depending on in/out setting: Max Bit Rate and Resample Bit Rate. Right now I have those on “auto” and “original” respectively. TIA.
Please check one thing.
Enter the Video app on your Rose device and click the gear icon (Settings) at the bottom left.
Is the “Use VLC Player” function currently ON?
If you turn on the “Use VLC Player” function, more extensions are supported than the default player when playing video files on an external hard drive.
If it is off, it is the default player use mode.
Hi Rosehan,
Thanks for the reply.  The setting has no effect on the issue.  I tried changing it.  No change.
Thanks,
Wolf359
