Hi there
I have just purchased a new Amp and looking to find out what Voltage setting I set up in my Rose 150B
The Amp I have purchased is a Synthesis 96DC - 25Watts Class A (below are the specs)
Any help would be appreciated.
- Power tubes (each ch): 2 X EL34/6CA7
- Tube driver (each ch): 1 X 12AU7/ECC82
- Input: OP/Amp NJM2114
- Output power (each ch): 25W A Class into 6ohm
- Frequency response: 20Hz to 20KHz - 0dB
- Power stage config.: Pentode configuration
- Input impedance (line): 50Kohm
- Sensivity: 300mV for max power
- Distortion: < 1% 25W 1KHz
- Signal/Noise ratio: >90dB (A-weight)
- Frequency response (Phono):
- RIAA stage 20Hz - 20KHz ± 0,5dB
- Gain (MM): 40dB
- Input impedance: 47Kohm
- Analogue Inputs (96DC): 3 Line
- 1 Phono (MM/MC high impedance)
- Output (96DC): 1 Rec Out
