Volume control from the Rose EA or Rose HIFI apli
I have a HiFi Rose RS130 connected to a hifi rose rd160 by an I2S cable, but I can’t control the volume from my Rose EA or Rose HIFI application. What should I do?
I had to configure the output select to enable volume control on my rs250a; check the I/O page look for a gear icon on the selected output and see if that allows you control.
Sorry, you’ve paid a lot of money for the RS130 + RD160 and you want really use the digital loosely volume control from the RS130?
Also you’ll get problems in playing DSD or MQA sources.
Take your IR remote(s) or try to buy a Logitech harmony.
