The volume for each source option does not work. If i set the volume for music to 0db or 5db and confirm, there is no diffrence in volume at all. If it would work this would be a great option! Can you explain please?
Hello @bavd
Is there any difference in sound even if I set the volume of other music streaming apps?
Try changing the volume settings such as Rosetube, Tidal, etc., and please check if there is no change in the volume.
My bad, i forgot the confirmation button! It works!
Thanks for your quick reply!
