Volume issues in RS150
Hi all,
I’m trying Qobuz and Primephonic apps via Airplay with the RS150 and the volume is significantly lower than using Qobuz Rose Hifi app. Besides, I cannot set the volume on the Qobuz/Primephonic apps (the slider is frozen!). Any way to change this?
Thanks in advance!
Qobuz app via Airplay with the RS150, the low volume problem
→ Have you tried the physical volume buttons on the side of your iPhone?
(Or slide down/up the iphone screen, you will see volume control of airplay)
Does the sound come out very low even when the volume is set to maximum?
→ Isn’t the volume frozen on devices other than Rose devices?
It works! Even at top volume is slightly lower than using Rose HiFi app but it’s ok. Using Airplay I can’t see neither VUmeters nor the format and resolution of the file. Is this normal?
Thank you so much!
VU mode don’t work with Airplay for now.
We will check if we can make it work.
It would be great! Thank you so much!
