Volume problem switching HDMI
When the Output ran over hdmi the switchback to loudspeaker output causes full volume that can‘t be tuned down. Only a full restart solves the issue. Can you fix this?
  1. Which Rose model are you using?
  2. When switching outputs while using HDMI, is it that volume control doesn’t work? If it doesn’t, does an error message appear?
Best Regards,
1.) It‘ s the RS520
2.) When switching back to loutspeaker Output volume is Max and can‘t be Controlled anymore. The volume Control is still working but without function. There is no error Message.
Regards
Carl
