I have the Rose connected to an AV processor. Does the volume that the Rose is set at before fixing the pre out level automatically adjust to 78? If the Rose volume is set at zero before setting the pre out level, there is zero sound. If the volume is set at any other level it seems the Rose automatically adjusts to 78.
Also, how do you determine the best level to set the pre out at when going into a preamp/processor. Do preamps/av processors have input sensitivity?
Finally, what is the benefit of one method of volume control (Rose controlling volume) over the other (setting the pre out level)?
