Bonjour à tous
Je souhaite utiliser un dac externe qui n’a pas de contrôle de volume. J’utilise mon intégré Accuphase pour contrôler le volume
Comment desactiver la commande de volume du Rs150b? Je n’y arrive pas
Merci
Bonjour à tous
Merci
Hello everyone
I want to use an external dac that doesn’t have a volume control. I use my Accuphase built-in to control the volume
How to deactivate the volume control of Rs150b? I can’t do it
THANKS
The software volume control function of your RS150b is turned off. If you adjust the volume on Accuphase, will the volume be adjusted on the RS150b as well?
Software volume control can be checked by clicking the gear icon in the input/output settings.
Justement je n’arrive pas à desactiver la commande de volume en Usb !! J’arrive a le faire pour la sortie analogique
Comment faire ?
Gil
I can’t deactivate the USB volume control!! I manage to do it for the analog output
How to do ?
Gil
I need a more detailed answer from you.
it is an Accuphase E5000 amp with Dac 50 card (Accuphase).
it is connected via USB.
in all cases the volume control is active, whether On or Off
As a result, the USB Audio interface of Accuphase E5000 amp with Dac 50 card and RS150b are confirmed to be different. In the future we plan to modify the USB Audio interface. Then I think the problem will be solved. We need some time to resolve this issue.
