Hello
Is it possible for the rose team to modify the existing vu meter to include this. Im sure others would appreciate it.
Thanks.
Hello
Thanks.
The VU meter in the photo you showed is currently supported by Rose devices.
You asked if it’s possible to modify an existing VU meter to include this. What does this mean?
Hello. Thanks for the quick reply.
Currently the VU meter looks like this
Is it possible you could make it look like 1st image I posted (Macintosh style)
Hope this makes it clearer.
Since Macintosh has a copyright on the blue Vu-meter, we have removed the corresponding Vu-meter.
Hello.
Thanks for the reply.
This has nothing to do with Macintosh. What I am suggesting is you use the current vu- meter Type -A style as in the second image ( RS150 also RS250) in this post I posted above. This is Green not blue, and take away the centre word “rose” and add a left a right separate box to look like my first image posted above.
Hope this is achievable.
Nice design. I like it.
@Discospuggs
I understand your request.
I have forwarded your requirements to our software team.
Once I receive their response regarding the possibility of adding this feature, I will let you know.
Appreciated. Keep up the good work.
Any update admin please.
We apologize for the delayed response.
At this time, there are no plans to make changes to the VU meter design.
After review, it was decided to maintain the current design, as the proposed changes do not align with HiFi Rose’s overall product concept and design direction.
