Vu Meter not displayed
I have issues with Vu Meters. They are not displayed all the time.
When they’re displayed, they work well but sometimes they disappear and I don’t know how to get them back.
I recently changed my setup to use an external DAC via USB. Software Volume Control is off.
What is the standard way to display the vu meters ?
Thanks for your help,
Hervé
Unfortunately for the time being you have to use coax. They’re aware of the problem and sorting it out. Hopefully they get it fixed soon.
We have an issue that when you’re using USB output, VU meter disappears.
We are working on it, I apologize for the inconvenience.
Thanks, at least I know that you’re someone is working on the project.
Hervé
Thanks. I tried both and it seems the sound is better with usb. I’m sending the audio to a Buchardt hub which drives my A500s (wirelessly).
