I have just encountered a scenario where the VU meters don’t function. When I try to engage the VU meter from the Rose App, it indicates that it’s ‘not supported in current mode’
Any idea on how to fix this issue?
- If VU Meter is activated on the Rose device on the screen where the Vu Meter does not work in the RoseConnect app, is it activated normally?
- Isn’t Vu Meter mode activated during video playback?
- What type of mobile phone are you using when using the RoseConnect app?
I have the same issue. Du you use the app on an iPad? It works for me with Android but not on IOS with an iPad.
