VU Meter not working June2022
I have updated to the most recent software.
The VU meter doesn’t work. I can enable it when playing music but then the DB dial/arm doesn’t actively move, it sticks at like 20db while content is playing. I have tried resetting the rose and different sources, Tidal, Spotify, YouTube etc but the same problem.
How is your audio system organized?
For example …
RS150 > (USB) > DAC > AMP > SPK…
It’s HIFI rose > output HDMI > AV receiver > speakers
HDMI output should work… I will check it with development team.
Thank you,
Any update on this?
The VU meter is still not working correctly.
Kind regards
Suschiel
Hello @Suschiel
Although there are differences between the sound sources, the L/R values may not be the same.
Thank you. I know that. I am an audiophile. I mean the meter just gets stuck and doesn’t indicate the correct db it just stick on 20db and doesn’t actively move according to the music.
I hope that makes sense?
Suschiel
Hello @Suschiel ,
Sorry for late reply.
We checked the issue you mentioned and working on it.
Thank you,
