Weak preamp voltage for subwoofers when using speaker output
I am using a pair of active subwoofers with my line array speakers plug into my Hifi Rose RS 520.
The problem is that the voltage output from preamp is really low, forcing the amps inside the subs to distortion level when trying to match speaker output.
I know that you can increase preamp output in the menu but doing so, that muted the speaker output.
Is it possible to increase the preamp output of the 520 and still use speaker output at the same time?
Thanks for any help.
@Lappy27
Unfortunately, on the RS520, increasing the preamp output via the menu automatically mutes the speaker output. Currently, it is not possible to use both high preamp output and speaker output at the same time.
We recommend using an external preamp or splitter if you need to feed both your subs and speakers simultaneously.
