Weather fail update
I found that the weather of Shatin in Hong Kong was not updated. Can you fix it?
I just checked and seems like the weather works now.
I will keep checking.
Thanks for your efforts, but the weather again failed update today
I just checked weather of Shatin via ROSE device and it says 17 degrees Celsius.
I searched for Shatin weather with google on my PC, it says 17 degrees Celsius.
I hope to check some possibilities,
  1. At the time of writing the post, which is 1 hour ago, was the temperature different when checked on ROSE device?
  2. The weather that Google/ROSE device shows are different from the local weather actually?
  3. How is the weather of Shatin on your ROSE device now? Is it wrong? If so, doesn’t it change even if you touch the ‘refresh’ button?
  1. Yes, it should be 16 degree Celsius
  2. Yes, it had been 17 degree Celsius for two days, yesterday afternoon should be 21
  3. It’s 17 and same as the local temperature
Maybe I tell you later if the actual temperature changes
My weather for Los Angeles will not update. When I try to reload it says no signal error.
Sha Tin should be 18 degree Celsius now(16/2 HKT 3.40pm) but it still shows 17
We will check weather.
Thanks, it seems work normally now
Don’t know why, it’s not work again
Hi there, @ROSELOA my 150b weather does not update as well, is around 10 degrees now but still showing 17 degrees, I am in Hong Kong/Kowloon city. Thanks
Hello @2olegendforeverwest and @miata22 ,
The weather doesn’t change even after touching the refresh button?
Yes, when it’s not updated, whatever you do it didn’t work
Last night it became ok
Hi. it worked all of a sudden, I believe many HK users experience this as well.
Correct, after touching the refresh button still couldn’t update, but at the moment is working for no reason.
It’s not working now again :sweat:
Now Sha Tin 16 degree Celsius but it shows 10 degree Celsius
Hello @aswiss
It would be appreciated if you could let me know which country or region weather is different.
Then I will send it to the Software team.
I have no weather data for southern Arizona. (Tucson). Just Phoenix which is vastly different. By the same token my RS 250 is missing completely the Mountain Time Zone, so a large percentage of the US is absent, and the clock on the 250 can’t be set to the correct time.
Hello @melm
  1. Please tell us the regional list of countries you would like to add.
    Regions that can be added will be added.
  2. Rose device–>Settings–>Date and Time —> TimeZone settings
    Please check if it set correctly. and set Auto set date and time to “On”
You are missing the Mountain time Zone of the United States. There are 4 zones in the continental U.S. Eastern, Central, Mountain and Pacific. You are missing the Mountain Time Zone, which is one hour earlier than the Central Zone. Some states within the Mountain Time Zone (like Arizona) do not use Daylight Savings Time, but you already have a switch to turn it off or on. States in the Mountain Time Zone Include Arizona, Colorado, Utah, New Mexico, and Alberta Canada.
The Mountain Time Zone of North America keeps time by subtracting seven hours from Coordinated Universal Time (UTC) when standard time (UTC−07:00) is in effect, and by subtracting six hours during daylight saving time (UTC−06:00). The clock time in this zone is based on the mean solar time at the 105th meridian west of the Greenwich Observatory
