Does any one know if you can change the temperature from Celsius to Fahrenheit.
I’m sorry but no Fahrenheit for now. I will check if I can add it.
Ok no Fahrenheit thank you for responding.
Please can add more cities from Greece .
Will be nice in near future update the weather location select is based from IP direction .
Thanks a lot
I will review with software engineer.
Thank You so very much, I appreciate that.
Fahrenheit will be added in next update. The next update will be in few days.
