Weiss 205 DAC sending volume
My system is based on an LG OLED 77" and AppleTV feeding a Rose 520 via HDMI. I want to add the Weiss 205 and use the S/PDIF coax out of the Rose and into the Weiss. From there I use the RCA output of the Weiss to a Spectral amp. Simple question really - will the volume control I use on the Apple continue to function and send variable volume through the Weiss and into the Spectral?
Actually the core question is…is the Rose 520 coax output fixed or variable?
@Barry
In the input/output settings of RS520, there is a gear-shaped settings button next to the icon for the connected DAC output. Click to set sample rate options.
Thanks for the help!
