So this means the ROSE 150 is better that the B ??
RS150B
RS150
DAC Chip ESS Technology, SABRE ES9038PRO sahi Kasei VERITA AK4499EQ
Output level 6.5Vrms (Balanced),
2.2Vrms (Unbalanced) 9.0Vrms (Balanced), 4.5Vrms (Unbalanced)
THD 0.0002%(Balanced,1KHz 6.5Vrms),
0.0003%(Unbalanced,1KHz 2.2Vrms) 0.0002%(Balanced,1KHz 9.0Vrms),
0.0003%(Unbalanced,1KHz 4.5Vrms)
THD + N 0.0003%(Balanced, 1KHz 6.5Vrms),
0.0004%(Unbalanced,1KHz 2.2Vrms) 0.0003%(Balanced, 1KHz 9.0Vrms),
0.0005%(Unbalanced,1KHz 4.5Vrms)
IMD -103dB (Balanced), -103dB (Unbalanced),
SMPTE 4:1, 60Hz:7kHz -101dB (Balanced), -100dB (Unbalanced),
Signal to Noise Ratio 121dB (Balanced),118dB (Unbalanced),
A-wt 120dB (Balanced), 117dB (Unbalanced),
A-wt
Dynamic Range Max 132 dB (CCITT filter) Max 132dB (CCITT filter)
Stereo Crosstalk Max -138dB, 20-20kHz Max -138dB, 20-20kHz
Output Frequency Response 20Hz to 20,000(+/-0.5dB) 20Hz to 20,000 (+/-0.5dB)
Output Impedance 50Ω 100Ω
