What causes RS130 to go into Power Standby?
I normally keep my RS130 powered 24/7 but I’ve seen this a couple of times, without knowing what would cause the unit to go into power standby.
@Tony22
Please check the video below. Is the following function activated?
That was it, @ROSEHAN. The Automatic Standby. I forgot I had that set. Since I stream music 24/7 it almost never goes into standby, but I guess when my radio streaming is interrupted it triggers the Standby function after the set time. Thanks.
