What input signals does the RS250A accept on coaxial and optical input? Is it just PCM or maybe DSD over PCM or even nativ DSD? I am considering buying a converter from HDMI to ‘DSD over PCM’ to connect the RS250 directly to an SACD player (audio HDMI out)
RS250A does not support ‘DSD over PCM’ for HDMI output.
For HDMI output of RS250A, only ‘DSD to PCM’ - up to DSD128 is supported.
Thanks for your reply, but my question is about the coaxial and optical INPUT of the Rose RS250A.
What do they accept? I connected a CD transport to the optical and the coaxial input, as I expected it accepts PCM. But do the INPUTS accept native DSD or “DSD over PCM”?
Thanks in advance!
Native DSD isn’t possible through SPDIF, only DoP!
This is independend from Rose…
