Hello, this is HiFiRose.
Q)
When using an external USB DAC, is it possible to control the volume through the ROSE device?
A)
It depends on which DAC you are using. DAC made to be compatible with UAC(USB Audio Class) are volume controlled in ROSE. For devices that do not support this function, the volume cannot be controlled through ROSE.
There is no option to fix volume of ROSE device when external DAC supports UAC.
Unfortunately, we don’t know all of which DAC supports UAC.
Please check if the DAC supports UAC.
