I lost access to all radio station with the latest firmware update. How can I bring back them? Moreover, I have this error message continously: Rose server connection failed
Same problem with youtube. The search button does not work and no accès to youtube videos.
Tidal works perfectly
Same here. Lost my favorites. Was lucky I had one station in “recently played” but the others are gone. I really appreciated when they added “song playing” automatically as it was a pain to have to do this manually. Finding actual streaming url’s is very difficult does anyone have a best practice here? Definite improvement needed in finding or scanning for LOCAL stations in the USA.
Not really when we always have this error message " Rose server connection failed. Moreover, this website does not have the four diffrent stations we already had before latest firmware upgrade
You are supposed to enter the radio streaming URL, not the home page URL.
It is not easy to find.
I will give you the radio URL address from the site you’ve told me.
Please try
Rose device–>Radio app–>+ button–>Enter the radio channel name in CH name and the URL.
Radio Paradise (320k) : http://stream-uk1.radioparadise.com/aac-320
Radio Paradise Rock Mix FLAC : http://stream.radioparadise.com/rock-320
Radio Paradise Main Mix FLAC : http://stream.radioparadise.com/aac-128
Radio Paradise Mellow Mix AAC 320k : http://stream.radioparadise.com/mellow-320
Enter the channel you listen to in the Add radio channel field.
My error message is gone : rose server connection failed and all the rosetube stations are available.
I cannot explained what happened but rose radio is working.
