I had seem, the unit is allow you to change the top roll off and bottom. for general purpose which filter has the best kick bottom response accordingly? or totally invert in the high roll off.
How can I change this filter?
I can find no mention of it in the owner manual.
For RS150/RS250/RS520, you can set the DAC filter from In/Out Settings–> Gear shape in Output–>FIR interpolation phase Filter.
Found it.
Thanks for your help.
Very accurate chart and description.
thanks for the information. very userful
Thanks for the chart.
