Which USB fiberchannel SFP?
Hello, The NIC SFP that comes with the unit works great but I cannot seem to find a USB SFP available to purchase. What are you guys using for the USB fiberchannel SFP?
@THANOS
I’m sorry to tell you that, RS130 does not support SFP+ modules.
The ports on RS130 are for SFP only. The maximum throughput of RS130 is 1Gbit/s.
I guess what I am trying to find is a USB fiber connector as my unit did not come with one? Is it supposed to?
Where can I buy one to use the fiber usb port?
@THANOS
We do not sell fiber USB ports separately. When you purchase the RSA720, a fiber USB port is included.
If you want to purchase only the fiber USB port, you will need to search the web.
Perfect. Thank you very much.
