Which USB Port does ROON Core connect to?
I have a MacMIni as my ROON Core. Roon is not showing up on my ROSE-RS250 Settings page. I think the problem is that I have the ROON Core, connected to the WRONG USB Port.
Which USB port should my ROON Core connect to please ?
For using the Roon Ready features with RAAT, you’ve connect the Roon Core and the RS250 through the LAN and not with USB.
Then you can activate the RS250 in the Roon audio settings.
The LAN ?? Are you saying I should run an Ethernet cable between the 2 boxes ?? I surely can do that, as I am using Wifi on the ROSE 250 .
Thank you,
Mike
Again: Using the RS250 as a Roon endpoint, then you need to use the network (LAN or Wifi, but I would prefer in every case the LAN) and activate it in the Roon settings.
If you use only USB, then the RS250 will act only as DAC and your Roon core as Roon endpoint.
In here you would not see any metadata on the display from the Rose.
