Hi all,
I got my RS250 since a few days and I am extremely pleased with the sound. I previously had a Bluesound Node 2021 and it’s definitely an improvement in terms of sound.
Unfortunately I am facing some instability with the wifi, which never happened with the Node nor with my Smart TV which are both sitting on the same shelf than where the RS250 is now. The wifi router is about 7 meters away without any walls in between (they’re at opposite ends of my living room).
Are there any specific tips to get the wifi more stable ? What I’m experiencing is that Tidal streams are often interrupted, the iOS app can’t connect to the rs250, etc… sometimes it’s ok for a few hours and sometimes it’s just unusable.
I am facing another issue with Bluetooth but it might be because I don’t know how to use it. I paired my Samsung smart TV with the RS250, I am seeing the RS250 in the available speaker list on the TV, I can connect to it but after I do so, no sound is coming out of my speakers. What else should I do to get the TV sound played by the RS250 ?
I am also unable to pair my iPhone with the RS250, I don’t see it in my iOS Bluetooth devices list and the RS250 doesn’t discover my iPhone when I do a Bluetooth search.
Thanks in advance for your help,
Hervé
