Can rose RS150 B able to play tidal tracks of MQA on a wifi setting as I don’t have Ethernet connection
Currently, Tidal does not support MQA.
Music can be played using either a Wi-Fi connection or an Ethernet connection.
Rosehan
Sorry your answer is incorrect.
Tidal still has MQA files on its website.
As far as i am aware it will not be removing these files but adding Hi-Res FLAC
Colin
Can I use wifi to access MQA
As long as your WiFi isn’t completely terrible, there should be no problem.
I agree with BorisM.
Anything to do with servers or streaming is always better with an ethernet cable so if you can possibly use an ethernet cable it’s just so much easier and a lot less hassle.
