I find that if the RS150 is left in standby mode for a while it cannot be switched on with either the remote or by the On/offf switch in the APP. The blue light does flash on the WiFi dongle though.
When I took it out of standby by using the RS150 touch screen the WiFi icon at the top right of the screen was not showing a connection and the app kept giving an error message of “Connection Failed”.
I had to switch off the WiFi in the settings menu and switch it back on again. It then connected to my network.
This has happened several times now.
Is this a bug and can it be rectified, please?
thanks
