WiFi not connecting
Hi! I found my RS250 on this morning but not connected to Wifi as it always is. I rebooted several times and it still could not find a Wifi network (there is a good one and I have lots of devices connected to it). I also went to the Wifi page to see that it was turned on and there were no networks listed there. So I tried a factory reset and when it got to the looking for WiFi page it just kept spinning.
Would you turn on hotspot tethering in your phone and try to connect your RS250 to the hospot?
To check if the WIFI of RS250 is working or not.
I jut purchased 150b. Going through setup and when it goes to WiFi I just see a spinning circle and cannot gent past it. Suggestions?
Have you connected the WIFI/BT dongle on the right port?
