Anyone had luck with wireless HDMI, I tried on brand which works but drops out often and has much distortion.
Wireless may cause distortion.
It is recommended that you use a wired HDMI cable of 5M or less.
BlairW55 personally I have a wireless adapter that I found on Amazon from a company called Braidol. It works well but not at full 4k resolution. I had to adjust the Display settings on the Rose to 1280x720p60 in order for the volume to sync. Hard wire is better if you’re looking for 4K of course or hopefully one day we will get some casting features. Hope that helps.
Thank you for your positive advice.
Currently, we are prioritizing software stabilization.
We will also forward your suggestions to the software team.
They will check and add more if they are available.
