Wireless Headphones for RS520
I’m looking for a wireless headphone solution to watch late night TV. I’ve got the RS520 hooked up to my TV using eARC and typically sit about 12 feet from the TV. I don’t want a wired headphone since it creates a trip hazard.
Any suggestions?
I’ve seen the FiiO BTA30PRO, Sennheiser BTT100 and Sennheiser RS 175.
Has anyone had success with any of these or any other solution.
@bdj964
Rose products support only the function of receiving and playing music from a smartphone when Bluetooth is activated.
In the opposite case, it is recommended to connect the pre-output to RS520 with a separate headphone amplifier because it does not support sound source transmission.
…and what if a subwoofer is already connected to the PreOut?
I use a Pride Sapphire RCA Y-cable (example picture) and tap the preamplifier signal for the subwoofer and headphone amplifier in parallel.
Hello Don,
There you go, you found a solution for yourself. I’m happy for you that it’s working for you now and that you’re not bothering any family members or neighbors at midnight.:clap:t2::+1:t2:
How did you connect the Filo now?
Analogue (RCA) or
Digital (OPT IN or Coax IN)…:v:t2:
Ooooh my God, I can’t read anymore. It’s all there.
I’m getting old​:tired_face::laughing:
