Anyone know if this would work to control volume.
Fosi Audio VOL20 Bluetooth Volume Control
If you want to use the VOL20 as a physical volume knob for the RS150B, it will not work technically.
The RS150B’s volume control and media playback must be managed through its own interface, the RoseConnect app, or the included remote control.
Thanks for the reply.I have the RS250. Will it work or same as RS150B.
Regards.
