I HAVE A 150B (ESS) dac chip . I am using the Xlr’s analog outputs to feed my integrated amp. Can the xlr’s analog outputs be voltage adjusted to match my integrated?
Hello @Scareface1
I received an answer from the person in charge of the question, it is possible that xlr’s analog outputs be voltage adjusted to match your integrated amplifier.
You can fix the desired value in the pre-out level setting according to the specifications of the integrated amplifier you are using.
