XLR Balanced Voltage settings not found
When I look at the output settings I only see mV options for Unbalanced/RCA outputs. It seems that the only way to use the BALANCED outputs is with the adjustable output . The input sensitivity only pertains to UNBALANCED from what I can see. Balanced outputs are analogue connections unique to the standard RCA connection.
In pre-out level settings of RS150B…
Values outside the parentheses are for “Balanced(XLR),” and values inside the parentheses are for “Unbalanced(RCA).”
Thank you for information.
