Does anyone know what is the best setting to put my fixed voltage output on when using XLR?
So to match the SR150B to my Jeff Rowland integrated amp.
Using 2000MV now. Should I go lower or higher…
Whatever most closely matches the volume of your CD player or other devices (excluding turntable). I use the highest fixed output voltage because it matches the volume of my CD player and Sony Hap-Z1es.
Check the manual of your amplifier and see if there’s input sensitivity.
If input sensitivity is 2000mV in the manual, 2000mV will fit for you.
@ROSELOA Seems that there is no mention of input sensitivity on my model in the manual.
Did check the output impedance of the RS150B it’s 50 Ohm, My amp has 36k Ohm input sensitivity.
So on this basis, it’s not a problem at all.
Anyways, spoke to Jeff Rowlands CS. They just say that the best is when the amp is at 60 to 70% volume it should be at a decent listing volume. So I have no numbers for the input. But I don’t think I can overdrive my amp easily.
