The fix mentioned under point 13 (Added DB cleanup for deleted files after subfolder scan) does not work or I misunderstood something.
I replaced the album Van Halen / “Balance” with the version “Balance (Expanded Edition)”.
After a rescan, both albums were listed, after re-creating the db it worked again.
Honestly, I like the RS 150 and still enjoy listening to music with it. However, there are simply a lot of bugs in the app, even if many are just cosmetic, that are immediately noticeable. I primarily use Roon for control; if I didn’t have it, I wouldn’t have a Rose device either.
Edit:
“My” music files are sorted by resolution. The deleted album was in the “FLAC” folder, and the new album is in the “24Bit” folder:
