My ROSE RSA 150B is repaired and I listen to quality music again thanks to streaming through this device. But I have a few questions. After replacing the whole audio board, some information started to appear differently than before, I want to ask you to explain this change.
Before the repair, the inscription ROSE 150B appeared in the upper left corner of the display and now the inscription ROSE 28 appears, but when I look at the information “System info”, the Model RS 150B is marked here.
When I turn on the signal path information, the information “Full MQA” appeared before the correction and now “MQA Authenticator” appears
Sidonius
