It is ad hominem, now second time. It does not matter what I currently have. Why would I spend a ton of money to have the same sound as over Wiim? RS130 is simply too big for my current setup. That is the reason I own an RS250. I will not talk about my skills and expirience in digital audio, it does not matter. What matters are the technical arguments you have. You should understand the basic principles of digital audio transmissions and talk with arguments. You obviously do not. I do not care if you own an pricey RS130. It is your money. There are a lot of reasons why would somebody own such a beautiful piece of hardware, but the sound is not among them. That is because on the output you have no sound, there is just an stream of coded information which cannot change because of budget gear. Time information can be of bad quality, but that is for the DAC to take care about.
The sound you should search in the DAC, not in the digital transport. I did not heard the RD160, but I assume it is singing beautifully and the two are the killer combo. I also do not know how good is RD160 in jitter rejection. This is one of the most important properties of an DAC which tells you how bad a transport and digital cables you can throw at the DAC. For instance, at Weiss DAC’s you can throw anything, it will sound the same.
(Warning: Extreme danger…for cyclists with training wheels)
It’s really starting to get really annoying
