Can someone point me to a spot that has the descriptions of each of the FIR filters?
Thx
Thx
My Oppo UDP-205 has same DAC and filters as the RS150. They only list the different filters with no description of each. So yes, try and decide…
Thanks for the feedback. Currently using min phase with slow roll off. I’ll plan on evaluating the other options.
HiFi Rose should address this and other items in a detailed owners manual!!
Good stuff. It’s kinda funny. I’m swapping between options and depending on the content, sometimes I can’t tell any difference, maybe I can. I have a pretty high resolution system, but old ears…
Âż en que menu del 150B esta la posibilidad de seleccionar un filtro u otro del DAC?
Gracias
Hello @nachocom
no sé español Lo explicaré con imágenes.
Por favor, haga clic en el área marcada en rojo
Seleccione la configuraciĂłn deseada en el paso 1 y haga clic en Aplicar.
Hi.
This synthesized, integrated story is a piece of work.
congratulations and thank you… many will find it useful.
Maxxim
